NI Linux Real-Time Discussions
Context Help Ctrl-H
I am running labview real time 2014 on a cRIO-9030.
When I press Ctrl-H on a real time executable, a context help window opens up. Does anyone know how to remove that window?
(3,626 Views)
When creating executables, .ini file is created automatically, together with the executable. If you add the following to the .ini file, it should disable the context help.
DisableContextHelp=True
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
(3,434 Views)
