NI Linux Real-Time Discussions
FPGA Interface C API for PXI (x86) use NI RT Linux?
Hello, i just started the project with NI RT Linux.
I have a project to work with NI RT Linux on PXI hardware platform using FPGA Module PXI-7951
When reading the document, I see that the FPGA Interface C API supports NI RT Linux on x86 as shown, detailed at page: , but at page it does not support FPGA Interface C API for PXI (x86) using using NI RT Linux
So how should I understand? Can FPGA Interface C API for PXI (x86) use NI RT Linux?
Thank you for reading, I hope you all answer my questions.
(1,549 Views)
Someone from NI can probably confirm but I suspect that bottom link is just out of date.
PXI used to run Pharlap for their real-time OS which is listed there. But now that is deprecated and they run LinuxRT. I would be surprised if this wasn't supported.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(1,448 Views)
Yes, that table is out of date. I'd recommend submitting some site feedback on that page at the very bottom right to flag it to get cleaned up.
~ Helping pave the path to long-term living and thriving in space. ~
(1,433 Views)
