NI Linux Real-Time Discussions
HDI compliant mouse not correctly working
Hi all,
I have a CVS-1458RT on which I connected a touch screen; the screen works perfect, and I can move the mouse on the screen.
So far so good.
But when I click with the 'mouse'; only the first click is registered, afterwards, no click is detected anymore.
When I pull out the usb connector and reconnect, I can again click one time and then no more. Moving the mouse works all the time.
When I connect the touch panel to another normal pc (win7); everything works fine, so it is definitely a driver problem on the linux.
Any idea how to check for the drivers and maybe correct them?
I did check following:
admin@NI-CVS-1458RT-01AE0DF7:/var/log# cat /proc/bus/input/devices
I: Bus=0019 Vendor=0000 Product=0001 Version=0000
N: Name="Power Button"
P: Phys=PNP0C0C/button/input0
S: Sysfs=/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=3
B: KEY=10000000000000 0
I: Bus=0019 Vendor=0000 Product=0003 Version=0000
N: Name="Sleep Button"
P: Phys=PNP0C0E/button/input0
S: Sysfs=/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1
U: Uniq=
H: Handlers=kbd event1
B: PROP=0
B: EV=3
B: KEY=4000 0 0
P: Phys=LNXPWRBN/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
U: Uniq=
H: Handlers=kbd event2
B: PROP=0
B: EV=3
I: Bus=0003 Vendor=0eef Product=0001 Version=0210
N: Name="eGalax Inc. USB TouchController Pen"
P: Phys=usb-0000:00:14.0-1/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/input/input3
U: Uniq=
H: Handlers=mouse0 event3
B: PROP=0
B: EV=1b
B: KEY=c01 0 0 0 0 0
B: ABS=3
B: MSC=10
N: Name="eGalax Inc. USB TouchController"
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/input/input4
U: Uniq=
H: Handlers=mouse1 event4
B: PROP=2
B: EV=b
B: KEY=400 0 0 0 0 0
B: ABS=a60800000000003
I: Bus=0019 Vendor=0000 Product=0006 Version=0000
N: Name="Video Bus"
P: Phys=LNXVIDEO/video/input0
S: Sysfs=/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input5
U: Uniq=
H: Handlers=kbd event5
B: PROP=0
B: EV=3
B: KEY=3e000b00000000 0 0 0
(3,832 Views)
Biebel,
Firstly, can you run the command lsusb -vvv and paste the results. Can you reproduce the problem and attach the Xorg log (use SSH or serial console to access your target, it should be located at /var/log/Xorg.0.log.) And finally, can you try to power off the controller, replace the eGalax-enabled touch screen with a normal monitor and try the mouse again? I'm concerned that the eGalax touch driver may be interfering with other pointer devices (like your mouse).
(3,345 Views)
I posted it in the following discussion:
https://decibel.ni.com/content/message/129293#129293
Bruno
(3,345 Views)
