NI Linux Real-Time Discussions
Help with cRIO 9030
Hello, I have a problem...
My cRIO have screen black in HMI, but the cRIO run the programs successfully while I run my program connected by ethernet in my pc.
can anybody help me? or you can say me what to do?
first of all, Thanks
(4,320 Views)
This is a question more suited to the official NI support forums. http://forums.ni.com/
(3,923 Views)
First let's check the simple things:
  • Make sure that "Enable Embedded UI" is checked in MAX for that target (Measurement & Automation Explorer)
Second, can you expand a bit on your setup:
  • What cRIO model are you using?
  • What monitor are you using?
  • How is the monitor connected? (e.g. are you using an VGA adaptor and if yes what model)
  • Can you copy the following log file of the target and post it: /var/log/Xorg.0.log?
(3,923 Views)
thanks crisan... but fixed it well, for months
(3,923 Views)
