NI Linux Real-Time Discussions
Icon for Real Time Executable
How do you change the icon on the real time executable?
(5,335 Views)
I also want to know if it is possible to change the icon in the Embedded UI
Image and video hosting by TinyPic
<script type="text/javascript" async src="//cdn.youracclaim.com/assets/utilities/embed.js"></script>
(5,132 Views)
LJHerskowitz,
What software stack are you using? What are the steps that you use to create the real time executable? Usually, when creating an app (the .rtexe), this itself is not something that can be executed directly but instead is loaded and run automatically by LVRT on startup. That is at least the case for LVRT 2016
(5,126 Views)
Hello Brad;
What I say is that when I create an executable in a Windows system, if I change the icon the, in the application, i have the small icon in the top left of the title bars, as following:
If I run the application in a cRIO with embedded UI, this small icon is the default labview icon. I want to be a specific icon (the same as the previous example), not the default labview one.
(5,118 Views)
Ah, ok, that makes sense. Unfortunately, that's a bit outside of my wheelhouse, let me see if I can't track someone down.
(5,113 Views)
Hi, unfortunately it is not possible to change the icon for the RT built application.  The reason being we did not expose that setting for RT as we did for desktop.
Embedded UI was added after the build specification dialog was designed, and at the time there was no UI available on the target so there was no need to allow users to change the icon.
(5,097 Views)
Thanks jonathan, so I'm going to delete the title bar of the dialogs
Regars
(5,080 Views)
