NI Linux Real-Time Discussions
Installation of pacemaker pcs
We are working on making a high availability cluster of two IC-3120 which run our Labview-software.
We want to do this using pacemaker and pcs.
Pacemaker is installed from source using this guide:
https://github.com/ClusterLabs/pacemaker/blob/master/INSTALL.md
We are then trying to install pcs from source using this guide:
https://github.com/ClusterLabs/pcs
Here we get the following error (snippet from console output):
Installing ffi 1.9.25 with native extensions
Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
    current directory: /usr/lib/ruby/gems/2.4.0/gems/ffi-1.9.25/ext/ffi_c
/usr/bin/ruby -I /usr/lib/ruby/site_ruby/2.4.0 -r ./siteconf20190802-6161-pvoxla.rb extconf.rb
*** extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of necessary
libraries and/or headers.  Check the mkmf.log file for more details.  You may
need configuration options.
Provided configuration options:
        --with-opt-dir
        --without-opt-dir
        --with-opt-include
        --without-opt-include=${opt-dir}/include
        --with-opt-lib
        --without-opt-lib=${opt-dir}/lib
        --with-make-prog
        --without-make-prog
        --srcdir=.
        --curdir
        --ruby=/usr/bin/$(RUBY_BASE_NAME)
        --with-ffi_c-dir
        --without-ffi_c-dir
        --with-ffi_c-include
        --without-ffi_c-include=${ffi_c-dir}/include
        --with-ffi_c-lib
        --without-ffi_c-lib=${ffi_c-dir}/lib
        --with-libffi-config
        --without-libffi-config
        --with-pkg-config
        --without-pkg-config
/usr/lib/ruby/2.4.0/mkmf.rb:457:in `try_do': The compiler failed to generate an executable file. (RuntimeError)
You have to install development tools first.
        from /usr/lib/ruby/2.4.0/mkmf.rb:542:in `try_link0'
        from /usr/lib/ruby/2.4.0/mkmf.rb:557:in `try_link'
        from /usr/lib/ruby/2.4.0/mkmf.rb:658:in `try_ldflags'
        from /usr/lib/ruby/2.4.0/mkmf.rb:1818:in `pkg_config'
        from extconf.rb:15:in `<main>'
To see why this extension failed to compile, please check the mkmf.log which can be found here:
  /usr/lib/ruby/gems/2.4.0/extensions/x86_64-linux/2.4.0/ffi-1.9.25/mkmf.log
extconf failed, exit code 1
Gem files will remain installed in /usr/lib/ruby/gems/2.4.0/gems/ffi-1.9.25 for inspection.
Results logged to /usr/lib/ruby/gems/2.4.0/extensions/x86_64-linux/2.4.0/ffi-1.9.25/gem_make.out
An error occurred while installing ffi (1.9.25), and Bundler cannot continue.
Make sure that `gem install ffi -v '1.9.25' --source 'https://rubygems.org/'` succeeds before bundling.
In Gemfile:
  ethon was resolved to 0.11.0, which depends on
    ffi
make[1]: *** [Makefile:32: get_gems] Error 5
make[1]: Leaving directory '/git/pcs/pcs-0.10.2/pcsd'
make: *** [Makefile:237: install] Error 2
The mkmf.log:
"pkg-config --exists libffi"
| pkg-config --libs libffi
=> "-lffi\n"
"x86_64-nilrt-linux-gcc  -m64 -march=core2 -mtune=core2 -msse3 -mfpmath=sse --sysroot=/srv/jenkins/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/6.5/objec$
In file included from /usr/include/ruby-2.4.0/ruby/ruby.h:36:0,
                 from /usr/include/ruby-2.4.0/ruby.h:33,
                 from conftest.c:1:
/usr/include/ruby-2.4.0/ruby/defines.h:101:19: fatal error: stdio.h: No such file or directory
 #include <stdio.h>
compilation terminated.
checked program was:
/* begin */
1: #include "ruby.h"
2:
3: int main(int argc, char **argv)
4: {
5:   return 0;
6: }
/* end */
Has anyone seen something similar?
Is it the C-compiler which is not properly set up?
(2,826 Views)
Hi aaroentr,
You'll need to interpret the error logs and compiler settings. The one thing that jumps out at me is this:
                 from conftest.c:1:
 #include <stdio.h>
 It looks like you're not finding the stdio.h header file. That header should be located in the /usr/include directory.
One potential problem I see is that your gcc command has a sysroot that shouldn't be required if you're compiling on the target. How are you generating the makefile? Where are you getting that sysroot flag from? What version of LabVIEW Real-Time is installed on the target?
Charlie J.
(2,780 Views)
Hi GatorBait
Thanks for your reply.
I have found stdio.h in /usr/include.
The makefile is not generated by me. It is included in the .tar.gz from the github repo.
I am not familiar with the sysroot flag. Should I be able to diable this and hopefully advance further?
The target has NI Linux Real-Time version 6.0.
Truls
(2,744 Views)
