NI Linux Real-Time Discussions
Real-Time Linux on NI PXI Embedded Controllers
There's a "Using Linux on a PXI Embedded Controller" webpage
is it possible to install real-time Linux onto one of these listed PXI embedded controllers and run VIs on it as a RT target?
(4,027 Views)
Hi arunsm,
No, this is not available. You cannot use NI Linux Real-Time on PXI(e) controllers with the LabVIEW Real-Time module.
There is a specific use case with LabVIEW Communications System Design Suite where NI Linux Real-Time is used on PXI(e) controllers, but this is not fully featured and is design for this specific use case.
Andy
PSE
(4,017 Views)
Yes, NI Linux RT (and LabVIEW Real-Time) is supported on most/all current PXIe Controllers.
Check the OS options on the product page for the controller you are interested. Here is for example the page for PXIe-8862: https://www.ni.com/en-us/shop/model/pxie-8862.html. Notice "LabVIEW Real-Time (NI Linux Real-Time)" listed in "Controller OS" drop down menu.
The comment that got posted about support being only for "specific use case with LabVIEW Communications System Design Suite" is old/outdated.
(1,457 Views)
