NI Linux Real-Time Discussions
Samba credentials not preserved upon reboot
I've just installed samba - 3.6.8-r8 from opkg on a 906x without problems and I've also added a user (same username and password as the one added to NI auth web config page) and tested it properly trough a windows client.
However, user credentials are not preserved upon reboot.
If I run this command upon reboot:
smbpasswd -e <username>
I get this error:
Failed to find user smbUser in passdb backend.
If I browse the pdpass with pdbedit -L command, the list is empty.
Any hint about how to sync Samba users to Linux users? Could this be related to the fact that niauth overrides standard user management tools like useradd?
Fabio
Fabio M.
NI
Principal Engineer
(4,545 Views)
Accepted by topic author Chuck_81
Discard the request. I've solved the issue by adding the following lines:
   obey pam restrictions = Yes
   passdb backend = smbpasswd
   passwd program = /usr/bin/passwd %u
   passwd chat = *new* %n\n *Re* %n\n *pa*
   username map = /etc/samba/smbusers
   unix password sync = Yes
to the [global] section of the smb.conf file
Fabio M.
NI
Principal Engineer
(4,007 Views)
Good, this one was a bit of a headscratcher that I hadn't really dug into, and with the difficulty folks have configuring Samba coupled with what we do to enable NIAuth users, I could see the possibility for headaches.
Mark the question as "Answered" with your own response.
(4,007 Views)
