NI Linux Real-Time Discussions
Segmentation Fault on cRio when running lighttpd fastcgi
I'm setting up my fastcgi on the linux target using the python, and lighttpd packages provided by opkg.
When I create my .fcgi file and try to run it, I get a Segmentation Fault.
I've successfully gotten lighttpd running with just returning outputs of .py scripts, and now I'm trying to set up a python based cms on the crio using fcgi.
the System web server is out of the way on another port, so port 80 is free for lighttpd.
Why would I be getting a segmentation fault from this?
(3,939 Views)
What resources did you use when configuring the crio? What packages have you installed? What debugging have you already done past ensuring that normal CGI support works?
(3,302 Views)
Randomly had a thought: one thing that could be happening here is the stack limitation leading to the segfault. From the shell where you're launching lighttpd, set the stack size to unlimited (ulimit -s unlimited)
(3,302 Views)
