NI Linux Real-Time Discussions
TIPC Protocol Support
Has anyone ever looked at TIPC protocol support on NI Linux Real-Time targets?  The open-source project states that any build after 2.6.16 should have the kernel support and will only need the user code/utilities.  Did this support remain in the NI Linux Real-Time kernel or was it removed?  Has anyone ever tried running TIPC protocol?
http://tipc.sourceforge.net/tipc_linux.shtml
(4,483 Views)
You can check what kernel features are present in our kernels by looking in /proc/config.gz:
admin@scot-9068:~# zcat /proc/config.gz | grep TIPC
# CONFIG_TIPC is not set
(4,178 Views)
That's one of the many use cases where it would be good to have a reliable, fully-reproducable deployment of an build environment for the cRIOs, so everybody could easily add/upgrade individual packages and rebuild images.
https://forums.ni.com/t5/Additional-NI-Software-Idea/cRIO-image-development-kit/idc-p/3819979
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(3,504 Views)
