NI Linux Real-Time Discussions
UDP Multicast primitive on cRIO-9068
Is there an issue using multicast on NI RT Linux?  I get "generic error 42" on the UDP Multicast Open using the Read/Write version.  If there is an issue can anyone suggest an alternative?
Kevin
(3,995 Views)
kwkengineer, since this is an issue that is showing up using all NI software on the 9068, the NI forums seem like the better place to ask this question: forums.ni.com
(3,198 Views)
True.  I did put this question in the wrong place...however just this very moment it looks like I found the problem.
The example doesn't use the "net address" input on the multicast open.  On my 9068 I only use one of the Eth ports.  Without the net address input the Open tries to open on all Eth ports and since one of mine is unconfigured...I get errors.
(3,198 Views)
