NI Linux Real-Time Discussions
Unable to compile uinput module on cRIO 9030
How did it fail? What did the console show?
Just re-read your post, yes, using the default (for all x86_64) config will likely fail.
Message 41 of 73
(2,743 Views)
3 linux pignuins after the grub bootloader
but I could do nothing...
Bruno
Message 42 of 73
(2,743 Views)
If you did step 15 (make nati_x86_64_defconfig) this will get you the configuration we use for shipping. Note that you do need to checkout the correct branch after cloning the repo
Message 43 of 73
(2,743 Views)
I'll try again, because somehow the nati_x86_64_defconfig file failed in my previous attemt.
Now I'm compiling starting from this defconfig..
Keep you updated when ready!
Bruno
Message 44 of 73
(2,743 Views)
HI all,
Just builded the Kernel succesfully with uninput, HIDRAW and evdev integrated.
The CVS-1458 starts with the new kernel; and i'm able to install the drivers from eGalax without any error.
Because I did this all with SSH and I'm home now, I can't test the touch panel itself
Tomorrow, I'll go to the office to test because I'm excited!
Bruno
Message 45 of 73
(2,743 Views)
Progress! it'd be great if you could do a quick writeup or at least mention whatever adjustments to the instructions I cobbled together to help others
Message 46 of 73
(2,743 Views)
Just went to the office, and got dissappointed
Touchscreen doesn't work at all
and NI-Max doesn't see the CVS, and the test VI I made before doesn't launch automatically..
the good thing though is that I've still access with SSL
Bruno
Message 47 of 73
(2,743 Views)
Which deamon needs to be enabled to see the CVS back into MAX?
(when I do a save reboot, it shows up in max, in normal boot not)
I tried following:
-started in safe mode
-CVS is visible in MAX
-formatted the CVS (in max), installed default software again
-started from scratch a new kernel build (with the options necessary for the ETouch)
-after booting, CVS doesn't show up anymore in MAX
-still touch problem...
Bruno
Message 48 of 73
(2,743 Views)
Hil all,
Finally, my touchpanel works!!
According to their manual (eGTouch Linux Programming Guide v2.5H) I had to change some items in:
/SourceCode/drivers/input/evdev.c
/SourceCode/drivers/input/mousedev.c
/SourceCode/drivers/input/joydev.c
with menuconf, I had to add the uinput, evdev and hidraw module and to remove the standard USB touch screen driver
After that, I compiled the kernel according the procedure as written before.
I could install the eGTouch drivers from their website.
When you start the deamon (eGTouchD, you get a error message that the libasound2 is not found.
With opkg install libasound2, I managed to download those
after restarting, the touch works.
BUT NOW:
-how can I activate the MAX connection again?
-the CVS linux realtime is not visible anymore in MAX?
Bruno
Message 49 of 73
(2,743 Views)
Some more info:
in the messages logfile, it gives a failre on the nikal not being found.
After digging, I found I can use the updateNIDrivers; which gives me following error:
admin@NI-CVS-1458RT-01AE0DF7:/usr/local/natinst/nikal/bin# ./updateNIDrivers
************************************ ERROR *************************************
* Kernel source does not appear to be installed for the 3.10.31-ltsi-rt29 kernel.
*    Installation of the kernel-source package for kernel 3.10.31-ltsi-rt29 is
*                   required to continue this installation.
make: *** /var/volatile/tmp/headers/kernel: No such file or directory.  Stop.
make: *** [clean] Error 2
Installing NI-KAL:
NI-KAL update failed.
make: *** [all] Error 2
ERROR: make of nikal kernel module failed, not installing kernel module.
   updateNIDrivers should be called again after fixing the problem.
   Logging failure...
   Include the file /tmp/niSystemReport.out.gz when contacting
   National Instruments for support.
I have to say that the in the modules folder which is created with the kernel, the natinst folder was missing.
So I copied the natinst folder from the previous kernel... and now it says that is not ok.
Do I maybe have to check a module in menuconfig for the nikal?
Bruno
Message 50 of 73
(2,743 Views)
