NI Linux Real-Time Discussions
Unknown package 'gcc'
Hi I was following this FAQ https://decibel.ni.com/content/docs/DOC-35053
And when attempting:
     opkg install gcc gcc-symlinks
I get these errors:
Unknown package 'gcc'.
Unknown package 'gcc-symlinks'.
Collected errors:
* opkg_install_cmd: Cannot install package gcc.
* opkg_install_cmd: Cannot install package gcc-symlinks.
opkg update and opkg upgrade work, but do not return any information, and do not solve the above errors. Any ideas?
Note i am able to ping www.google.com so I dont think its my network.
(6,743 Views)
Do you have an Internet connection on Linux device.
(5,022 Views)
Firstly, welcome adamAlias132132
Now, are you using a 2013(sp1) or 2014 OS image on the controller? Post the results of uname -a if you're not sure.
Secondly, just a quick check, but did you run opkg update first prior to attempting to install software through opkg?
(5,022 Views)
No, I did not run opkg update first before installing some software through opkg, could that cause this issue?
Results of uname -a:
3.2.35-rt52-1.0.0f1 #1 SMP PREEMPT RT Wed Jun 12 09:5
7:26 CDT 2013 armv7l GNU/Linux
(5,022 Views)
Accepted by topic author adamAlias132132
Ah, I see the problem. You are using 2013 and have not enabled the package manager feeds. Go into the files /etc/opkg/angstrom-*-feed.conf and uncomment the feed URL lines (remove the "#" and any leading spaces), rerun opkg update, and try to install those packages again.
(5,022 Views)
