NI Linux Real-Time Discussions
Using ser2net with NI 9871 on Linux RT
Hello everyone, I have a sbRIO board that has NI 9871 RS485 C-series Module. I'm trying to forward this serial port over TCP using ser2net, however i don't seem to be able to read data from the ports when I'm doing a serial loopback although this works fine when using Visa and LabVIEW. For now I'm suspecting that ser2net needs some port configuration to be able to utilize the serial ports under the name  /dev/ttyNISERIALslot1port0. i tried the configuration in this topic,
https://forums.ni.com/t5/NI-Linux-Real-Time-Discussions/Setting-Serial-Port-Configuration-on-Startup...
to set the baudrate and "ixon" parameter using stty but still no luck. Does anyone have any experience with this ?
Message 1 of 1
(797 Views)
