Using serial mouse on cRIO-9030 embedded UI with FTDI/USB interface
does anyone know how to configure the cRIO-9030 in the XFCE desktop environment to use a clasical serial mouse with FTDI/USB interface to command the device pointer instead of an USB mouse.
The FTDI/USB interface is recognize by Linux RT as ttyUSB0 in /dev directory.
this is the result of dmesg Linux command :
I can create an xOrg.conf file with serial mouse config in, but the choice of mouse type isn't display in "Mouse and Touchplay".
this is my xOrg.conf :
Section "ServerLayout"
    Identifier     "X.org Configured"
    Screen      0  "Screen0" 0 0
    InputDevice    "Mouse0" "CorePointer"
    InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
    ModulePath   "/usr/lib/xorg/modules"
    FontPath     "/usr/share/fonts/X11/misc/"
    FontPath     "/usr/share/fonts/X11/TTF/"
    FontPath     "/usr/share/fonts/X11/OTF/"
    FontPath     "/usr/share/fonts/X11/Type1/"
    FontPath     "/usr/share/fonts/X11/100dpi/"
    FontPath     "/usr/share/fonts/X11/75dpi/"
EndSection
Section "Module"
    Load  "glx"
EndSection
Section "InputDevice"
    Identifier  "Keyboard0"
    Driver      "kbd"
EndSection
    Identifier  "Mouse0"
    Driver      "mouse"
    Option        "Protocol" "auto"
    Option        "Device" "/dev/input/mice"
    Option        "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
    Identifier   "Monitor0"
    VendorName   "Monitor Vendor"
    ModelName    "Monitor Model"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        #Option     "SWcursor"               # [<bool>]
        #Option     "kmsdev"                 # <str>
        #Option     "ShadowFB"               # [<bool>]
    Identifier  "Card0"
    Driver      "modesetting"
    BusID       "PCI:0:2:0"
EndSection
Section "Screen"
    Identifier "Screen0"
    Device     "Card0"
    Monitor    "Monitor0"
    SubSection "Display"
        Viewport   0 0
        Depth     1
    EndSubSection
        Viewport   0 0
        Depth     4
    EndSubSection
        Viewport   0 0
        Depth     8
    EndSubSection
        Viewport   0 0
        Depth     15
    EndSubSection
        Viewport   0 0
        Depth     16
    EndSubSection
        Viewport   0 0
        Depth     24
    EndSubSection
EndSection
The "Mouse and Touchpad" pointing device choice : (only "Generic USB K/B"  choice is displayed, but not "serial mouse"   )
Thanks.
(3,678 Views)
  1. I think you forgot to attach your Xorg.conf
  2. You can install a helpful screenshot program (note that this will be undone when you format/reinstall). From the console:
    • opkg update
    • opkg install xfce4-screenshooter
(3,321 Views)
