NI Linux Real-Time Discussions
VISA USB-RAW on cRIO-9030
Why don't you just use the standard HID stack (as the device seems to be speak the standard USB HID protocol) ?
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
Message 11 of 16
(1,683 Views)
Hi Metrux,
Can you explain your suggestion further? While I have my device and application working as described in this thread I'm always happy to gain more understanding or find a better way.
Message 12 of 16
(1,674 Views)
@Jolt wrote:
Hi Metrux,
If the device is really an USB HID device (as it seems - dont have one here to confirm that), it should be automatically detected by the linux input subsystem and appear under /dev/input/ (assuming they didn't forget to compile in the generic usb hid driver).
Message 13 of 16
(1,663 Views)
Maybe, and this is admittedly a bit out of my depth, but the only way I could get the device to be available through my LV code was as described above. The OS does recognize it natively as an HID device but without an address in MAX/LV I couldn't figure out how to target it with the USB Raw functions in LV.
Message 14 of 16
(1,649 Views)
I guess, LV doesn't have an binding for the standard input/event device API, you could just write one.
IIRC you can call C code from a VI, correct ? Well, then just call libevdev:
https://www.freedesktop.org/wiki/Software/libevdev/
(this library supports Linux as well as BSD).
If the driver is already bound to the device, you won't get direct access via USB subsystem.
You'd have to unbind the driver (or reconfigure udev to completely ignore that device).
OTOH, reimplementing the whole HID stack in userland isn't an entirely trivial job. I don't see much value in going through all of that, doing an completely own implementation, just for one project.
Instead I'd advice just to use the standard API.
Message 15 of 16
(1,642 Views)
I just posted a new proposal @ idea exchange:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/LV-binding-for-Linux-Unix-evdev-API-eg-USB-touch-pane...
Message 16 of 16
(1,639 Views)
