NI Linux Real-Time Discussions
VNC on cRio 9030
I would like to take control of my cRIO 9030 through VNC.
Does anybody already did that ?
Christophe
Message 1 of 8
(8,174 Views)
I did that at some point quite a bit back, not sure if it was something with the actual packages available on the repo or something one-off that I did. It seems that there's not really anything installable from the feeds.
As such, you basically have three options going forward:
  • building a VNC server on the controller itself or through something like a cross-compilation setup
  • using the same build system that NI uses to build a vnc server package to copy to the target and install
  • attempt to find a suitable package for a compatible distribution and manually extract and install
I personally would recommend either of the first two options
Message 2 of 8
(7,179 Views)
Finally I found a solution. I installed RealVNC on the cRio-9030.
I used VNC for Linux.Generic installer 64 bits.
It works perfectly.
Message 3 of 8
(7,179 Views)
Hello Christophe.
Could you please write what exactly I have to do to install VNC on cRIO? I have downloaded VNC-5.3.1-Linux-x64-ANY.tar.gz archive on my computer, but I'm not sure how I can install it on cRIO and setup the connection after all.
I'd appreciate any help. Thanks in advance.
Message 4 of 8
(7,179 Views)
svpug
Try the steps in the attached document.
Kind regards,
Andreas
Message 5 of 8
(7,179 Views)
With the last document it works perfectly
Image and video hosting by TinyPic
<script type="text/javascript" async src="//cdn.youracclaim.com/assets/utilities/embed.js"></script>
Message 6 of 8
(7,179 Views)
Thanks for the excellent writeup, SAndreas
Message 7 of 8
(7,179 Views)
Message 8 of 8
(7,179 Views)
