NI Linux Real-Time Discussions
What to do? packagegroup-ni-base... might cease to work if package syslog-ng is removed
My colleague asked me to downgrade syslog-ng from 3.5.4.1-r0.102 to 3.3.5 so our existing syslog-ng.conf files may be used without having to hunt down the incompatibilities which are blocking us. Apparently (see the log below) this might interfere with packagegroup-ni-base. This is troubling. We are using the cRIO-9033 as a Linux computer running our applications and so we might not need these applications. However, we depend on NI-MAX and safemode to keep working and can't afford to destablize the system.
  • Should I use one or the other of the --force switches mentioned?
  • Build 3.3.5 from the .tar.gz and try and "make install" and sort out the issues after?
I will go back to my colleague and also ask to leave it as it is.
Tim
opkg remove syslog-ng
No packages removed.
Collected errors:
* print_dependents_warning: Package syslog-ng is depended upon by packages:
* print_dependents_warning:    packagegroup-ni-base
* print_dependents_warning: These might cease to work if package syslog-ng is removed.
* print_dependents_warning: Force removal of this package with --force-depends.
* print_dependents_warning: Force removal of this package and its dependents
* print_dependents_warning: with --force-removal-of-dependent-packages.
(3,196 Views)
That dependency is there mainly to signal that syslog-ng 3.3.5 is the version that NI tested the distribution on. I would try --force-depends to get 3.5.4.1 installed and see if it works.
(2,929 Views)
