NI Linux Real-Time Discussions
Write Citadel using Trace (DSC Module)
hi
i have some question,
do the NI cRio 9068 with NI Linux RTOS allow us to use "Trace" function palette from DSC Module to comunicate with Citadel historian?
i want to log all data that i read from sensor using cRio direcly to Citadel. (no need to sent the data to host)
i have issue if i use "VxWorks" cRio's because DSC Module not supported in RT.
i hope with NI Linux RTOS cRio already solve this issue..
same with the database toolkit. this toolkit not support in RT if using VxWorks cRio.
do this toolkit works in NI Linux RT?
please advise..
(4,318 Views)
amatz11,
Neither Citadel APIs (or database) in DSC module, nor database toolkit supports NI Linux RT now.
If you want to do logging locally on NI cRIO 9068 (NI Linux RT), you may need to consider use TDMS APIs. Thanks.
(3,759 Views)
