NI Linux Real-Time Discussions
bad target restart (firmware unknown)
steph0ff wrote:
Hi Brad,
thanks for the very useful links!
No problem. Glad to help.
VI_BROKEN (0): [VI "NI OPC UA Client.lvlib:Read Int64 Array.vi" (0x00726aa8)]
VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI OPC UA Client.lvlib:Read Int64 Array.vi" (0x00726aa8)]
this->flags=33563136, compilerError=6
VI_BROKEN (0): [VI "NI OPC UA Server.lvlib:Write Bool.vi" (0x004fb6c8)]
VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI OPC UA Server.lvlib:Write Bool.vi" (0x004fb6c8)]
VI_BROKEN (0): [VI "Current Value Table.lvlib:Form Single Group.vi" (0x00a863c8)]
VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "Current Value Table.lvlib:Form Single Group.vi" (0x00a863c8)]
etc..
It seems that there is an error in the call of opc functions, maybe I made some mistakes in the code. Now I check and give you a feedback.
But in any case I think that I can't debug the NI-OPCUA .so shared libraries, with gdb, right? (it's not shared libraries developed by me, so I haven't source code, maybe I've to check if library is compiled with -g).
Firstly, this is not a SEGFAULT issue in the library. If it were, LabVIEW would simply crash, not report that a VI is broken (there's some other reason for that: the VI in the lvlib is not wired as expected, it is unable to find some resource, etc.)
Even if it were a segfault issue, we're talking about NI software, so it is a standard NI support process issue. I would work through that process as they're more familiar with the normal issues that customers run into.
Message 11 of 11
(977 Views)
