NI Linux Real-Time Discussions
cRIO 9068
which directory cRIO uses to save the deployed VI?
(3,725 Views)
A VI that's deployed through the LabVIEW project remains in memory and is not saved to disk.
If you set a startup application, the built application is saved under the lvuser's home directory, I'm not 100% sure of the path, but you can use tools from the shell to find the path.
(3,073 Views)
thank you very much
(3,073 Views)
