NI Linux Real-Time Discussions
gcc: error trying to exec 'as': execvp: No such file or directory
I'm pretty new to the myRIO and I'm trying to compile a simple C hello world. I did install gcc with opkg and I'm trying to compile with:
gcc -o test test.c
The response is:
Did I forget an install? Thanks for the help.
(10,550 Views)
Try installing the binutils-symlinks package. This should also install binutils.
(8,923 Views)
Yes, thank you for the fast response! Seems to work now!
(8,923 Views)
