NI Linux Real-Time Discussions
sbRIO-9651, enable wlan0 with MAX
Hi Jayraj,
how did you configure the /etc/network/interface and wpa_supplicant.conf files?
Do you mind sharing those files?
Luca
Message 11 of 16
(2,195 Views)
Hi Luca
Sorry for the late reply. As I am new to RIO devices and to Linux platform, I did refer to some online resources to configure the files, but I think none of them worked out and I ended up using the original one. I am attaching both the files for your reference (I also had to use one .bin file for the usb driver which I downloaded from Linux repository). Let me know if it worked for you as well.
Jayaraj
Message 12 of 16
(2,195 Views)
One little update. running ps I don't see the wpa_supplicant in the processes and also in /var/run/wpa_supplicant I don't see the PID.
ifconfig gives me this output:
admin@NI-sbRIO-9651-030707e8:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:80:2F:19:42:10
          inet addr:192.168.0.127  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::280:2fff:fe19:4210/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:5966 errors:0 dropped:443 overruns:0 frame:0
          TX packets:1345 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:558602 (545.5 KiB)  TX bytes:344541 (336.4 KiB)
          Interrupt:54 Base address:0xb000
eth1      Link encap:Ethernet  HWaddr 00:80:2F:19:42:11
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:77 Base address:0xc000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:138 errors:0 dropped:0 overruns:0 frame:0
          TX packets:138 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:12736 (12.4 KiB)  TX bytes:12736 (12.4 KiB)
usb0      Link encap:Ethernet  HWaddr 00:80:2F:19:42:12
wlan0     Link encap:Ethernet  HWaddr E8:4E:06:1C:3B:8B
Message 13 of 16
(2,195 Views)
Luca
Looking at your ifconfig, this is what I used to get when I started interfacing with usb WiFi. I had also tried setting up an adhoc network using Linux commands, which had worked for me. Were you able to proceed and see the MAX configuration?
Jayaraj
Message 14 of 16
(2,195 Views)
Hi All
A problem that I face is, MAX allows me to configure wifi in DHCP only and the IP (172.16.0.1) and subnet mask (255.240.0.0) that it assigns to it is constant. It is unable to provide IP address to its clients and I have to switch to manual IP assignment based on the subnet mask that is shown in MAX. Is there any solution for this?
Update: I modified functions.common file in /etc/natinst/networking/ to change the subnet mask to commonly used ones, but the IP that the client receives is bogus, unless I configure it manually. I am unaware as to how to configure the networking files for the DHCP to run smoothly. Any idea?
Jayaraj
Message 15 of 16
(2,195 Views)
Hi All
I face the same problem as mentioned above. I am able to access the MAX page and select the 'create wireless network' option, but the dhcp server is not able to give IP to my PC which tries to connect to it. Only when my PC is configured for a static IP with the same subnet mask will it get connected to the SOM.
Arya
Message 16 of 16
(2,195 Views)
