I had built a raspberry pi cluster and after I was done I immediately wanted to build one with a out myRIOs. I figured I'd document the process in case I get side tracked and someone wants to run with the torch or should I get it working then someone will have some steps to follow. I'm interested in the benefits of a cluster have access to a asic like device (FPGA) at each node. I will finally see if the usual means of replication can distribute the image incase users choose not to self compile.
STOP:This document is a work in progress. Save yourself some time. When the process is documented and working I'll remove this label.
I had previously followed several guides and tutorials to get the pis setup so I'll post those for easy reference.
1. http://www.southampton.ac.uk/~sjc/raspberrypi/pi_supercomputer_southampton.htm
2. http://coen.boisestate.edu/ece/files/2013/05/Creating.a.Raspberry.Pi-Based.Beowulf.Cluster_v2.pdf
Useful Links:
1. http://www.mpich.org/downloads/
2. tduffy summary of installing c and c++ https://decibel.ni.com/content/message/65322#65322
Walkthrough:
- Create a MPI user account, give the admin account a password. The user account will be what we use to communicate to each node.
From MAX select Set Permissions which should open the WIF
>add pasword to the admin by clicking change password
>add a account "mpirio" by clicking the +
>add a password of "mpi" for "mpirio"
>add "mpirio" to the user group
- Add a home folder for the mpirio user
>open ssh as admin
>cd ..
>mkdir mpirio
>chown mpirio mpirio
>mkdir mpirio/mpich_install
>chown mpirio mpirio/mpich_install
- Set time in MAX (otherwise you may get warnings about timestamps from the future...)
>from time settings tab in max, set date/time and time zone - edit /etc/opkg/angstrom-base-feed.conf to look like:
>vi /etc/opkg/angstrom-base-feed.conf
remove the # to resemble the line below. Use i to insert then delete the "# ". You also need to remove the "us." from the feed as the server name changed. See Jack's document for other feeds supported.
src/gz angstrom-base http://feeds.anstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/
save the file and exit (escape, shift : (colon), wq, <enter>) - remove the lock on libc6
>opkg flag ok libc6 - update libc6
>opkg upgrade libc6 - Install binutils
>opkg install binutils
>opkg install binutils-symlinks - install gcc packages (unable to compile simple c code, add install binutils above,
>opkg install gcc
>opkg install gcc-symlinks - C++ support (required per https://decibel.ni.com/content/message/65322 see BradM's Post)
>opkg install g++
>opkg install g++-symlinks- (optional) Fortran
>opkg install gfortran
>opkg install gfortran-symlinks
- Install the Standard C library
note: you must cd to your home directory then use the -t option to specify the directory you are in. This is because the default temp directory is not large enough to download the package to. This may take awhile.
>cd ~
>opkg install libc6-dev -t /
>opkg install libstdc++-dev
>opkg install make - Make sure the stdc++ library is in usr/lib and create a link if its incorrect
cd ~/../../usr/lib
ln libstdc++.so.6 libstdc++.so - Go ahead and make sure the language of your choice works. A simple hello world should do.
- Download mpi source
>mkdir ~/mpich
>wget ~/mpich/http://www.mpich.org/static/downloads/3.1.1/mpich-3.1.1.tar.gz - Unpack source
>tar xfz ~/mpich/mpich-3.1.1.tar.gz - Make build directory.
>cd ~
>mkdir mpich_build - Configure the build (if you installed fortran drop the disable)
>cd ~/admin/mpich_build
>/home/admin/mpich/mpich-3.1.1/configure -prefix=/home/mpirio/mpich-install --disable-fortran --disable-f77 --disable-f90 - make the build
>make - Install MPI
>make install - Export the path to mpi (is a temporary setting)
>export PATH=$PATH:/home/mpirio/mpich-install/bin - Check for success (should see path to mpi functions)
>which mpicc
>which mpiexec - Make a testing directory to make sure everything works
>cd ~
>mkdir mpi_testing
>cd mpi_testing - Get myrio app and add it to a machine file
>ifconfig
>vi machinefile
>press i and enter ip address 10.2.132.61 in my case, press escape, wq, press enter - Test mpiexec
>mpiexec -f machinefile -n 1 hostname
>this should output the hostname from MAX - Test c code by running the example cpi.c, this program will calculate pi across multiple nodes, rebuilt again and fixed g++ before configuring same error
>mpiexec -f machinefile -n 2 ~/mpich_build/examples/cpi, tested recompiling cpi.c same error, wrote simple c code using mpicc same error
>affects python also http://lists.mpich.org/pipermail/discuss/2014-March/002396.html
>error emailed mpich.discuss
[mpiexec@NI-myRIO-1900-03037f65] control_cb (/home/admin/mpich-3.1.1/src/pm/hydra/pm/pmiserv/pmserv_cb.c:200): assert (!closed) failed
[mpiexec@NI-myRIO-1900-03037f65] HYDT_dmxu_poll_wait_for_event (/home/admin/mpich-3.1.1/src/pm/ydra/tools/demux/demux_poll.c:76): callback returned error status
[mpiexec@NI-myRIO-1900-03037f65] HYD_pmci_wait_for_completion (/home/admin/mpich-3.1.1/src/pm/hdra/pm/pmiserv/pmiserv_pmci.c:198): error waiting for event
[mpiexec@NI-myRIO-1900-03037f65] main (/home/admin/mpich-3.1.1/src/pm/hydra/ui/mpich/mpiexec.c:44): process manager error waiting for completion - currently looking at openmpi
>cd ~
>mkdir openmpi
>mkdir openmpi_build
>cd openmpi
>wget http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.1.tar.gz
>tar xfz openmpi-1.8.1.tar.gz
>cd ~/../mpirio
>mkdir openmpi_install
>cd ~/openmpi_build
>/home/admin/openmpi/openmpi-1.8.1/configure --CCFLAGS=-march=armv7-a --CXXFLAGS=-march=armv7-a --CCASFLAGS=-march=armv7-a -prefix=/home/mpirio/openmpi_install -q
>make all install (takes atleast 2 hours compiling on target, note research crosscompiling)
Results:
CXXLD otfprofile
otfprofile-collect_data.o: In function `std::list<StackType, std::allocator<StackType> >::_M_insert(std::_List_iterator<StackType>, StackType const&)':
collect_data.cpp:(.text._ZNSt4listI9StackTypeSaIS0_EE9_M_insertESt14_List_iteratorIS0_ERKS0_[std::list<StackType, std::allocator<StackType> >::_M_insert(std::_List_iterator<StackType>, StackType const&)]+0x3c): undefined reference to `std::_List_node_base::_M_hook(std::_List_node_base*)'
otfprofile-collect_data.o: In function `std::list<StackType, std::allocator<StackType> >::_M_erase(std::_List_iterator<StackType>)':
collect_data.cpp:(.text._ZNSt4listI9StackTypeSaIS0_EE8_M_eraseESt14_List_iteratorIS0_E[std::list<StackType, std::allocator<StackType> >::_M_erase(std::_List_iterator<StackType>)]+0x1c): undefined reference to `std::_List_node_base::_M_unhook()'collect2: ld returned 1 exit status
make[10]: *** [otfprofile] Error 1
make[10]: Leaving directory `/home/admin/openmpi_build/ompi/contrib/vt/vt/extlib/otf/tools/otfprofile'
make[9]: *** [all-recursive] Error 1
make[9]: Leaving directory `/home/admin/openmpi_build/ompi/contrib/vt/vt/extlib/otf/tools/otfprofile'
make[8]: *** [all-recursive] Error 1
make[8]: Leaving directory `/home/admin/openmpi_build/ompi/contrib/vt/vt/extlib/otf/tools'
make[7]: *** [all-recursive] Error 1
This is not supported by NI. Do not contact NI support as they will not be able to help. Feel free to send me (Kyle-H) a pm if you'd like to see this finished or have any ideas why a step is failing.
Issues:
- When I try to compile c code I see this error. gcc: error trying to exec 'cc1'
>install cpp, the default angstrom kernel feed placed cc1 into cpp - I see a bunch of lines when compiling the mpi source that date happened in the future
>set date/time in max for system - While running the configuration I'm presented with an error that the script couldn't figure out the ar interface.
Opening up the config.log which appears at /home/admin/mpich/mpich-3.1.1/config.log, I found this (see config.log below).
the configure script expects the ar command to accept the cr and u modifiers which the GNU versions supports.
http://linux.about.com/library/cmd/blcmdl1_ar.htm
config.log
configure:6676: checking for ar
configure:6692: found /usr/bin/ar
configure:6703: result: ar
configure:6729: checking the archiver (ar) interface
configure:6745: gcc -c conftest.c >&5
configure:6745: $? = 0
configure:6747: ar cru libconftest.a conftest.o >&5
ar: invalid option -- 'r'
BusyBox v1.19.4 (2013-06-20 07:58:10 CDT) multi-call binary.
Usage: ar [-o] [-v] [-p] [-t] [-x] ARCHIVE FILES
configure:6750: $? = 1
configure:6756: ar -NOLOGO -OUT:conftest.lib conftest.o >&5
ar: invalid option -- 'N'
configure:6759: $? = 1
configure:6778: result: unknown
configure:6794: error: could not determine ar interface
- Examples ended up in mpich-3.1.1 directory
>make sure to run the configure script while in the build directory
- How do I replicate my system? I tried using dd but now the status light is blinking twice
>Make sure you run any partition functions from the safe mode as this can and has caused a corrupt os on the linux rt controler. So I did end up really messing up a myrio with this. Don't use dd on the root fs while in run mode. - running the /configure script says cannot find iostream.h
