I have a project file using .Net 4 (VS2010, properly update) which I opened in VS2013, upon opening with no warning all NI license.licx lines were removed with no warning whatsover.
This should never happen, if something is going to be changed the user should be informed what is happening, especially if it's going to break a build.
