Log charts such as the ones pictured in the screenshot I attached are common in the oil industry. Many oils companies use NI equipment and write LabView and Measurement studio based software. The collected data is often plotted in log charts. It would be nice if NI would consider offering a vertical graph control in both Measurement Studio and the LabView products.
