I ran into an issue where I needed cRIO driver set 19.6 for an older target, I only had 19.1 installed and a whole bunch of newer sets.
The should be an option to install driver sets (for installation to a target) regardless if newer sets are installed. Not every customer uses the latest and greatest cRIOs.
