What: installing a package on a newly installed machine where only NIPM has been installed. Dependencies to e.g. DAQmx Runtime and Labview Runtime
The problem: the installation will fail as NI Package Manager does not know the feed locations for the dependent packages. If these packages had been installed previous and uninstalled, then the feeds would be known and the installation could pass.
Proposed solution: Whenever a package requires NI products as dependencies, the Package Manager should automatically search / add the feeds from NI.com and install them
Marking this as a duplicate of the idea that was moved from the Additional NI Software Idea Exchange.
