In the Item View, if some files are insert in a folder, you need to open all folder to make sure your solution is up to date :
Why not add the Blue Dot to the folder too :
I don't know also if it's a good idea to allow to have file in multiple location in this view. This can be confusing.
Regards
Maxime R.
CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
CTA - Certified TestStand Architect / Architecte TestStand Certifié
