an avenue for reporting bugs/error? other users encountering the same issue can also contribute more information for better debugging... post can be internally-archived/removed once issue is resolved
earlier today, updated the NIPM and now the mouseover event over the feed list for updates (over 2 seconds) crashed the NIPM (Debug/Close program) without any option of sending error reports
