As discussed in this thread, it would be helpful to be able to programmatically change the NI Package Manager settings. I personally am interested in changing the highlighted defaults. Maybe this could be done via the NIPM command line interface. Or a setting file, so it could be deployed as a NI Package.
Settings of Interest
