Why is NI Package Manager's GUI the only Windows program I have seen that does not support Alt+F4 as a close application keyboard shortcut? It would be nice if there was at least some keyboard shortcut to close the GUI. It is a bit annoying since every other NI application supports this.
Bill, NI Package Manager 21.8 added support for Windows 11 and the main windows no longer uses a custom title bar, so now Alt-F4 works as expected. Closing this idea as completed.
