user can select path to install software
You can, you just need to change the register:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015BtzSAE&l=en-US
It should be user friendly, not through a registry key.
The installer module allow this, why not the package module ?
