NI Package Manager (NIPM)
Building NI Packages for older versions of NI Package Manager
I'm making an update to a package I've made in the past and I'm trying to deploy it to my one of my systems. I'm running into an issue with deploying with this error message:
errors:
- Error -125081: Package 'my-package' requires a newer version of Package Manager. To update, navigate to the Package Manager UPDATES tab and update the NI Package Manager package. After updating, retry this transaction. (Compatibility value 200601 is less than package value 200702.)
I'm in a position where I can't update the Package Manager (It's a long story, but it's not doable). Is there a way in NI Package Builder where I can build new packages targeting older versions of Package Manager?
(2,430 Views)
Accepted by topic author Mason.Chou
The system you build the NI package with will need to have the version of NIPM you want it to be installable with. It appears that the version of NIPM installed is used/listed at the minimal required version. You can find older versions of NIPM from the download pages offline installers link.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,387 Views)
Hey Bill,
A bit late, my IT department is extremely slow with catching up to the modern times. I just tried this and it works.
Thanks!
(2,269 Views)
