NI Package Manager (NIPM)
Corrupt Installer for Labview
So can you run NI Package Manager and try using it to install LabVIEW 2020?
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Message 11 of 22
(4,694 Views)
How do I do that?
Message 12 of 22
(4,691 Views)
NI Package Manager should be in your Start Menu then LabVIEW and Drivers should be on the first page of Browse Products
NI Package Manager in Start MenuNI Package Manager in Start Menu
NIPM on openNIPM on open
After selecting LabVIEWAfter selecting LabVIEW
Bill Eisenhower
Message 13 of 22
(4,685 Views)
I do not have the NI package manager in my start menu. What should I do? How do I get it?
Message 14 of 22
(4,682 Views)
Well it seems like your PC thinks it already has it installed. I am guessing that happened from you failed install.
Check to see if you have C:\Program Files\National Instruments\NI Package Manager\NIPackageManager.exe on your PC. If not, I would file a service request about how to recover from this state.
Bill Eisenhower
Message 15 of 22
(4,672 Views)
How do I request a Service request?
Message 16 of 22
(4,621 Views)
support.ni.com
Message 17 of 22
(4,615 Views)
Accepted by topic author AnonymousCode
Thank you so much for your help. Technical support determined that it may be a problem that can only be solved by reinstalling all of windows from scratch because sometimes if the files are deleted before windows uninstalls the software, it thinks that the software is still installed,
Message 18 of 22
(4,551 Views)
I ran into the same issue about not having NIPM installed but it thinking that it is. You can use wmic in command window with product get Name,LocalPackage to find the msi files for NI Package Manager and its supporting packages to uninstall them. Uninstall via command line with msiexec.exe /x "<file>.msi /qb for each item; there should be about 4 items with names containing NI Package. Then you should be able to reinstall NIPM.
Bill Eisenhower
Message 19 of 22
(4,507 Views)
Can you give me detailed command for uninstalling the NI package manager
Message 20 of 22
(3,420 Views)
