NI Package Manager (NIPM)
Custom Feed Pointing to Releases from Private GitHub Repo
I would like to add a feed pointing to GitHub Releases. According to this documentation (Package Manager 2023 Q3: new feature - Incorporate support for URL redirection, commonly referred to as URL forwarding, in Package URLs), it should be possible. However, I would like to ask if it is possible to configure a feed for releases from a private GitHub repository. Can I configure an SSH key somehow?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(717 Views)
Does anyone know anything? Scott Richardson?  Aaron Peña?
Michał Bieńkowski
CLA, CTA, CPI
(659 Views)
Even with 2023 Q3 had issues with feed to public GitHub releases but found workaround. Wrote the whole blog post about here: NIPKG feed with GitHub releases | YABAP
When it comes GitHub private releases it will be more difficult since NIPM does not support authentication. Check this post for more detail: Sharing Feed with a customer - NI Community You can also give a vote here: Add authentication capabilities to NIPM feeds - NI Community The authentication seems to be low priority in NIPM dev team.
___________________________
Dawid Wozny
Certified LabVIEW Architect
Certified Azure Administrator
(318 Views)
