NI Package Manager (NIPM)
Error Installing NI Package
I am trying to install the NI Package Manager to work with DAQmx libraries, I am trying to replicate the same process I did with another machine.
But with this other computer it flashes the NI PM and it disappear.
In this case I am using windows 7 SP1 64-bits, 32 GB RAM with 1.81 TB of free space.
See bellow the errors I am getting on the file errors sow in errorlog.txt while I am trying to install.
I follow the steps in this link, but it is still not working, I also try to install older versions of the NI PM but it is always the same.
does anyone know how to fix this problem to be able to install NI package manager?
Thanks in advance
Best regards
***  errors sow in errorlog.txt  ***
===== 2020-Dec-17 16:24:45.777612 =====
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125090
Request type: 2
-125090: A plugin returned one or more errors at the beginning of the transaction.
File: source\nipkg_client\pkgclient\PluginInteraction.cpp
Line number: 106
Additional error information:
-125522: There was a problem with calling to the database of installed packages (SQL function call 'sqlite3_prepare_v2' returned error code 11 with error message 'database disk image is malformed'). Note: In order to perform the current operation, you might need to run nipkg.exe as Administrator.
File: E:\dev\_r\1\nipkg\source\shared_agents\Base/ErrorHandler/ErrorInfo.h
Line number: 574
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125082
Request type: 3
-125082: An error occurred while getting the list of installed packages.
Line number: 163
Line number: 574
===== 2020-Dec-17 16:24:45.812614 =====
Exception in PreInstall::InstallPackageManager. Error code: -126308
Failed to install NI Package Manager
-126308: Error '' occurred when installing NI Package Manager.
File: source\preinstall\Main.cpp
Line number: 639
(3,253 Views)
I'll ask the easy question first - are you running NIPM as an administrator?
GCentral
(3,244 Views)
Yes, I am running as administrator.
Sorry, for not mention it, I thought it was one of the steps on the link.
(3,201 Views)
was a solution posted for this error while trying to install LabVIEW???
(2,528 Views)
