NI Package Manager (NIPM)
Error while installing labVIEW 2020 SP1 32bit
Hello Every one I am trying to install labVIEW 2020 SP1 32 bit and facing error "an error occurred installing a package: ni-webserver". I need help
(1,432 Views)
If you do not need to be using LabVIEW features related to web services, you could try to unselect that option when installing, which will likely not install the package that is failing to install.
You can obtain more detailed logs for others to help debug this install failure. Please follow the instructions in Generating and Locating NI Package Manager Error Logs for obtaining Package Manager and MSI log files. Specifically, enable MSI logging, attempt to install again to reproduce the error, and then review the new log files that were updated and created. You can post the log files on this forum thread for others to review as well.
The files of interest include any updated and any new files in these directories:
  • %localappdata%\National Instruments\NI Package Manager\Logs\
  • %localappdata%\National Instruments\NI Package Manager\Logs\NIPkgLogs\
  • %localappdata%\National Instruments\NI Package Manager\Logs\WinInstMSI\
Scott Richardson
https://testeract.com
(1,406 Views)
