NI Package Manager (NIPM)
LabVIEW installation problems: ni-rabbitmq (3.7.3.49153-0+f1)
Been trying to install LabVIEW through the NI package manager but the above error or the one in the attached picture keeps coming up.
I have tried all the solutions at https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019YYdSAM&l=en-IE , apart from looking at the logs, as I couldn't find them on my machine.
I'm running a 64bit Windows 10 machine. Let me know if you need any more info.
Any help would be greatly appreciated. Thanks in advance
(4,802 Views)
The logs would be necessary to get insight into the underlying cause.
Scott Richardson
https://testeract.com
(4,751 Views)
Found the logs.... please see below
===== 2020-Oct-18 21:38:38.105342 =====
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125083
Request type: 30
-125083: An error occurred while installing a package: ni-skyline-rabbitmq-support (19.6.0.49152-0+f0)
File: source\nipkg_client\pkgclient\PluginInteraction.cpp
Line number: 258
Additional error information:
-125530: An error occurred while installing the MSI at 'niskyline_rabbitmq_configi.msi'.
File: C:\dev\107\s\nipkg\source\shared_agents\WinInstall/ErrorHandler/ErrorInfo.h
Line number: 102
===== 2020-Oct-18 21:51:03.655154 =====
Request type: 30
-125083: An error occurred while installing a package: ni-rabbitmq (3.7.3.49153-0+f1)
Line number: 258
-125441: The executable returned error '-1' after running the custom execute command 'path='"C:\Users\niall\AppData\Local\Temp\nipkg-e1e9-eecd-b480-f00c\data\RABBITMQ\InstallRabbitMQ.bat"', arguments='3.7.3''.
File: C:\dev\107\s\nipkg\source\shared_agents\Base/ErrorHandler/ErrorInfo.h
Line number: 317
Hope this is enough info
(4,747 Views)
Accepted by topic author antisocialphysicist
Unfortunately, the problem you are experiencing is a known issue. Please follow these instructions to work around the issue.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIbbSAE&l=en-US
Let me know if this does not resolve your problem.
(4,692 Views)
This worked!! Thanks for your help
(4,676 Views)
