NI Package Manager (NIPM)
NI-488.2 not recognized by Visual Studio C++
I'm attempting to run the power step up example code included with the NI-488.2 package, however whenever I attempt to compile it in Visual Studio I always get the same issue. First the compiler doesn't can't find the ni4882.h header, but even when I attempt to fix this by using the entire directory for the include at the top instead of the file name, it still doesn't recognize any of the functions from the header file when they're referenced in the body. I'm at a bit of a loss as to how to resolve this issue and I haven't found any help online. Does anyone have any suggestions?
(2,104 Views)
I think you accidentally got this posted in the wrong forum. This does not appear to be related to NI Packages.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,101 Views)
Which forum should I post it in then?
(2,094 Views)
Probably the Instrument Control forum: https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/bd-p/140
Bill Eisenhower
(2,091 Views)
Thank you!
(2,087 Views)
