NI Package Manager (NIPM)
NI Package Builder: Error with defining parent folder (..\) paths
I think I may have found a bug in NI Package Builder (NIPM) 19.1. I was trying to have the package output to be a location up and down another folder tree by using a ..\ relative path. However when I build, I get an error of an invalid path. One a second attempt, NIPM will be forced to close due to error. If I specify the location as an absolute path, I do not get any errors. However the Output Directory is saved a relative parent with ..\.
1st Attempt Invalid Path Error
2nd Attempt Error that forces NIPM closure
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,829 Views)
Hey Bill, I can reproduce the issue you mention. When a user specifies ..\ notation, NIPB converts that to .\..\. Loading a absolute path later resolves to .\..\ as well. It is our intention to support building to relative sibling directories. This appears to also occur with 19.0.  I created a bug with ID: 317274. I am not aware of any workaround right now. We will investigate. Thank you for reporting.
Scott Richardson
https://testeract.com
(2,775 Views)
Just my humble opinion, but there should be a configuration option in the builder that allows you to select absolute or relative paths
(621 Views)
