NI Package Manager (NIPM)
NI Package Manager 2023 Q3 released!
NI has released Package Manager 2023 Q3 this week.
Notable features include:
  • Added support for custom directories, such as D:\my directory\, when specifying where a package installs files.
    • Note that "package builder" applications, like LabVIEW and NI Package Builder, will need to expose this capability before it is available in those applications.
  • Package Manager allows feed URLs to redirect when download package from hosted web services, such as GitHub, and OneDrive.
    • NIPM previously returned an error with the message "Redirection to another URL is forbidden."
  • You can now manually disable specific feeds in Package Manager's Settings window.
  • Documented existing arguments for automating an installer, specifically --prevent-activation--hide-completion, and --autoinstall-nipkg.
  • Documented existing configuration options that control the behavior of Package Manager, that you can set using nipkg.exe config-set.
    • Added a new option nipkg.enable-NI-connectivity, which when set to false disables features that contribute to timeout delays on systems that cannot connect to ni.com.
  • Documented the list of nipkg.exe commands supported.
Refer to the NI Package Manager Release Notes and Manual pages for additional information.
Scott Richardson
https://testeract.com
(2,076 Views)
Hi Scott,
Still no plan to add NIPM to Microsoft's winget?
This (or other similar tools/install options) is the missing part to fully automating NI software installs from A to Z on the command line or in scripts. And it would greatly simplify the current process (go to ni.com, search, download, install) by doing that in one command.
See: https://forums.ni.com/t5/NI-Package-Management-Idea/Simplify-NI-software-install-by-using-winget/idi...
Thanks!
(1,743 Views)
