NI Package Manager (NIPM)
NIPM CLI log file
I would like to install/uninstall packages using Command Line Interface AND get a log file, or at least error code to know if it was successful.
The NIPM help indicates that I can use this option:
--output-transactions[=<fichier-destination>]
 So I tried this command, without succes (no log file created, log file still empty if I create if manually before executing the command):
start /wait Install.exe --passive --accept-eulas --prevent-reboot --output-transactions=C:\Users\rpasquie\Desktop\log.txt
This command works, but of course I don't have a log file:
Please, could you help me?
(2,741 Views)
Hi Romain.P
The command:
 Did you try this with quotation marks for the location, for example like this:
start /wait Install.exe --passive --accept-eulas --prevent-reboot --output-transactions="C:\Users\rpasquie\Desktop\log.txt"
Shezan.Nabiel
(2,607 Views)
Yes, no file created.
(2,580 Views)
