NI Package Manager (NIPM)
Repair always hangs at Finish
Trying to repair a VISA 19.0 installation due to isseues when buidling app with VISA 19 - the package manager will always hang forever at the last stage (Finishing).Previously it would hang at NI Certificates, but updating that alone worked without any problems. Having done that I restarted the 19.0 repair and underway it starts to call a regular installer it seems to repair other components...then that closes, and the repair process hangs at Finishing indefinitely...At first I thought this was another firewall issue (if I try to update to 19.5 I get the same internet connection issue-warning as many others here...), but the fact that it seems to hang after that extra installer-window has closed makes me wonder if this could be something else as well...? I tried instead to force a reinstall by running our volume license installer with the reinstall parameter - but now that will just call NIPM - which then says that it does not understand that parameter...So I'm stuck.
(2,524 Views)
The last items in the NIPkgLog when it hangs on failed repairs like these are:
14:36:59.865632 WIA: Done removing package from database | name: ni-visa-19.0-dotnet-development-support | version: 19.0.0.49152-0+f0
14:36:59.865632 WIA: About to add package to database | name: ni-visa-19.0-dotnet-development-support | version: 19.0.0.49152-0+f0
14:36:59.872633 WIA: Done adding package to database | name: ni-visa-19.0-dotnet-development-support | version: 19.0.0.49152-0+f0
14:36:59.875633 WIA: ===== API END OnTransactionStep ========== Transaction: Reinstall | package name: 'ni-visa-19.0-dotnet-development-support' | package version: '19.0.0.49152-0+f0'
14:36:59.882636 FA : ===== API BEGIN OnTransactionEnd ==========
14:36:59.882636 FA : [ BEGIN == Running 0 custom executes in postall queue in the following order. ]
14:36:59.882636 FA : [ END == Done running custom executes ]
14:36:59.882636 FA : About to close database
14:36:59.884635 FA : Done closing database
14:36:59.884635 FA : ===== API END OnTransactionEnd ==========
14:36:59.884635 WIA: Calling MetaUninstaller to repair products installed by WinMIF.
and then we hang forever...
(2,466 Views)
Hi Mads,
It sounds like there could have been some kind of corruption with the NI-VISA 19.0 install - did you manage to get around this issue eventually?
Alasdair
(2,272 Views)
