NI Package Manager (NIPM)
Running NIPM without admin rights
Is it possible to run NIPM without admin rights? I'm contemplating using it to redistribute reuse code, but requiring admin privileges every time a user would install or remove a package causes some issues.
(3,149 Views)
I am pretty sure you cannot currently. There is an idea under consideration for it right now. You may want to kudo it if you have not already.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(3,121 Views)
Does anyone know of a workaround for running NIPM without admin rights?
I don't want to install packages, but I would like to be able to see what packages are installed, as well as download packages and dependencies for offline installation.
It seems like I should be able to run NIPM without elevated privileges until I try to install something.
(773 Views)
Have you tried using the command line interface? That would let you list the installed packages from the normal user permissions.
nipkg.exe list-installed
Bill Eisenhower
(764 Views)
Thanks - that's super helpful!
(748 Views)
