NI Package Manager (NIPM)
The proper use of the NIPKG CLI command list-actions or execute-action
Hey Everyone,
I'm wondering if anyone knows the proper use of the list-actions or execute-actions commands used with the nipkg CLI.
I've gotten the help and it says:
list-actions - Show available actions for an installed package
nipkg list-actions [OPTIONS]... PACKAGE-NAME
Show available actions for a given installed package.
Returns all actions if no package name is specified.
PACKAGE-NAME - The name of the installed package.
OPTIONS
--suppress-incompatibility-errors
Suppress forward incompatibility errors.
WARNING: Suppressing errors could leave your system in an unusable state.
GLOBAL OPTIONS
--config=[PATH],-c=[PATH]
Allows the caller to specify an absolute path to a custom configuration file.
ALIASES
actions-info
lsactions
The execute actions is very similar.  I have run it without any PACKAGE-NAMEs and get "1-Launch" but I have been unable to get it to work when specifying a package name, regardless if I use an already installed package or other package.  I just get errors like:
Error -125088: An error occurred while processing the installed packages.
Additional error information:
Error -125403: The feature cannot be used because a required object or function is missing (mediator.OnTransactionListActions(...)).
So I figure I must be misunderstanding something.  This isn't hurting anything, but I have started an NXG library to implement the commands and I'm trying to flush out the command set so I've got it the next time I might need it.  Any help in understanding this command would be appreciated.
Erich
(2,505 Views)
My understanding is that list-actions will give you what options a given package has. execute-action lets you call an available action on an NI package. I am guessing you need to do something to define actions for your package. At least in LabVIEW 20XX, there does not appear to be defined my the Package Build Specification.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,482 Views)
Thanks for the insight CL_eisenwr.  I wonder if that has something to do with the post actions.  It might also have something to do with the NI Package Builder specifically.  I think I'll investigate that a little bit as well and report back, unless someone else that knows for sure comes along.
Erich
(2,471 Views)
