NI Package Manager (NIPM)
What is ni-ceip-x86 error message
Can somebody explain and solve the issue installing uninstalling LabVIEW? What is ni-ceip-x86 error? This cannot be new but there is nowhere I can find.
(2,875 Views)
Have you looked at NIPM Error logs for more details? KB about NIPM Logs
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
(2,808 Views)
A possibility is that some of the files in the "ni-ceip-x86" are missing, so the uninstall fails when it tries to run them.
I suggestion is to:
  1. Run NIPM
  2. Click the Gear in the upper right corner
  3. Click "Show full version numbers and show hidden packages"
  4. Go to the Installed tab, use the Search on the right and search for ni-ceip-x86
  5. Click the checkbox on the left of the package name, then click the Repair button.
  6. Now try to uninstall LabVIEW (or whatever you want), and hopefully that package will uninstall correctly now.
(2,795 Views)
