NI Package Manager (NIPM)
how to upgrade package manager through command line
Hi Bill,
Try "nipkg upgrade --accept-eulas -y" to silently upgrade everything.  "nipkg upgrade --accept-eulas -y ni-package-manager" will upgrade just NIPM.
Michael B.
Product Support Engineer
Message 11 of 24
(5,391 Views)
I tried this with NIPM 19.0 & 19.5 and it does work. Even running as admin did not help.
The only available action for ni-package-manager is Launch.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Message 12 of 24
(5,383 Views)
I was able to use the following command line to upgrade NIPM 19.0 to 19.5:
nipkg upgrade --force-locked --accept-eulas --assume-yes ni-package-manager
Note: If you might be in a situation where the target computer has NIPM 19.0 installed and no one has launched NIPM since NIPM 19.5 became available, then you should run nipkg update from the command-line first, so that NIPM can "refresh its feeds" in order to see the latest updates (e.g. NIPM 19.5) before running the above command.
Allen Hsu
Message 13 of 24
(5,333 Views)
The given command does work for 19.0.0 to update to 19.5.1. However it does not appear to work for 19.5.0 to get to 19.5.1
Working NIPM 19.0.0 upgrade to 19.5.1Working NIPM 19.0.0 upgrade to 19.5.1
Failing 19.5.0 upgradeFailing 19.5.0 upgrade
However I was able to work out a way via a series of commands to get 19.5.0 to be updated to 19.5.1. I hope this can be simplified to the update and upgrade commands like 19.0->19.5.1. Having the single consistent self-updating command would make it easy for updating older deployments.
NIPM 19.5.0 to 19.5.1 upgrade script
nipkg update
nipkg upgrade --accept-eulas --assume-yes ni-package-manager-released-feed
nipkg update
nipkg upgrade --accept-eulas --assume-yes ni-package-manager-upgrader
nipkg upgrade --accept-eulas --assume-yes system-windows-x64
nipkg upgrade --accept-eulas --assume-yes ni-package-manager-deployment-support
Bill Eisenhower
Message 14 of 24
(5,321 Views)
Now that NIPM 19.6 is available, I tried the to upgrade 19.5.1 via the command line to 19.6. The update and upgrade combination does not work. However my 19.5.0->19.5.1 procedure did work.
Bill Eisenhower
Message 15 of 24
(5,285 Views)
Updating NIPM via the command line might be easier with the offline installer automation as shown in this thread.
Bill Eisenhower
Message 16 of 24
(5,241 Views)
I'm confused, so how can I upgrade NIPM using command line? I tried different options suggested in this thread and non of them working.
ni-package-manager is not installed or is not upgradable. No operation will be performed.
I saw that with NIPM is installed also
ni-package-manager-upgrader 20.7.1.49158-0+f6 windows_x64 Application used to upgrade the package manager.
Can I use it somehow from command line to upgrade NIPM?
EDIT:
Nevermind, I figured it out 😅
C:\Program Files\National Instruments\NI Package Manager\Updater>Install.exe --passive
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 17 of 24
(4,876 Views)
This returns immediately "detached" from the installation. I need my script to wait until the install finishes because what I am actually trying to do is install a package I created without it failing due to outdated NIPM.
I run these steps in Powershell:
$nipkg_exe = "C:\Program Files\National Instruments\NI Package Manager\nipkg.exe"
cmd /c $nipkg_exe update ni-package-manager ni-package-manager-upgrader ni-package-manager-released-feed system-windows-x64 ni-package-manager-deployment-support
cmd /c $nipkg_exe upgrade --force-locked --accept-eulas --assume-yes ni-package-manager ni-package-manager-upgrader ni-package-manager-released-feed system-windows-x64 ni-package-manager-deployment-support
 The output of the upgrade command is "Packages are not installed or are not upgradable. No operation will be performed."
Then later on in the script my install fails:
Error -125081: Package '<package name>' requires a newer version of Package Manager. To update, navigate to the Package Manager UPDATES tab and update the NI Package Manager package.
Which can be resolved manually but I am literally writing this complicated script because I don't want to do this incredibly basic automation.
So does anyone have a script to actually update NIPM on Windows and return a success or failure?
Edit: ran this in cmd "C:\Program Files\National Instruments\NI Package Manager\Updater>start /wait Install.exe --accept-eulas --prevent-reboot", no quiet flag so I can see the popup, it said no upgrade to be performed. Then I MANUALLY opened NIPM, it had a progress bar stating updating NIPM updater, and showed upgrade available. I still don't know how to make NIPM realize it needs an upgrade without looking at it with my cold dead eyes.
Message 18 of 24
(2,380 Views)
I would try excluding the upgrader package, not sure that needs to be installed. You could consider the install order and put in dependency order: system-windows-x64 ni-msiproperties eula-ms-dotnet-4.8 ni-msdotnet4x ni-package-manager-deployment-support ni-package-manager
I recommend using the --verbose flag to maybe get more information.
Scott Richardson
https://testeract.com
Message 19 of 24
(2,344 Views)
Thanks for helping!
Same result:
PS C:\Users\ci-worker> cmd /c $nipkg_exe update system-windows-x64 ni-msiproperties eula-ms-dotnet-4.8 ni-msdotnet4x ni-package-manager-deployment-support ni-package-manager
PS C:\Users\ci-worker> cmd /c $nipkg_exe upgrade system-windows-x64 ni-msiproperties eula-ms-dotnet-4.8 ni-msdotnet4x ni-package-manager-deployment-support ni-package-manager
PS C:\Users\ci-worker> cmd /c $nipkg_exe upgrade system-windows-x64 ni-msiproperties eula-ms-dotnet-4.8 ni-msdotnet4x ni-package-manager-deployment-support ni-package-manager --verbose
 Open NIPM GUI -> "updating updater" -> update available
"Fortunately" I have dozens or hundreds of systems to try this on.
edit: this is the output of the same command after opening NIPM gui
PS C:\Windows\system32> cmd /c $nipkg_exe upgrade system-windows-x64 ni-msiproperties eula-ms-dotnet-4.8 ni-msdotnet4x ni-package-manager-deployment-support ni-package-manager --verbose
eula-ms-dotnet-4.8 is already the newest version.
ni-msdotnet4x is already the newest version.
ni-package-manager is already the newest version.
The following packages will be upgraded:
ni-msiproperties (23.8.0.49254-0+f102) to ni-msiproperties (24.8.0.49248-0+f96)
ni-package-manager-deployment-support (23.8.0.49300-0+f148) to ni-package-manager-deployment-support (24.8.0.49281-0+f129)
system-windows-x64 (23.8.0.49300-0+f148) to system-windows-x64 (24.8.0.49281-0+f129)
Installing 0 package(s); Upgrading 3 package(s); Removing 0 package(s); Downgrading 0 package(s)
Need to get 9.98 MB of archives.
After this operation, 0 bytes of additional disk space will be used.
Do you want to continue? [y/n]
Message 20 of 24
(2,298 Views)
