1 | |
1 | |
1 | |
1 | |
1 |
It would be nice to have the an API function to get the current progress stuff.
Allways when i am using the progress with PostUiMessage inside a sequence
I do not know what the current progress is. It would be nice to save it at start of sequence
now modify it with PostUiMessage
and on the end you are can able to set it old values again.
Regards
Juergen
