NI TestStand Idea Exchange
asilos
Add Git to supported source code control providers
Status: Completed
TestStand 2025 Q2 has a git pane that allows you to connect to Azure, BitBucket, GitHub to perform source control on sequence files.
Git would be a valuable addition to be made to the source code control providers that you have already since it is widely used.
7 Comments
t.kendall
This should have the vote of everyone in the community.
bienieck
Active Participant
Lack of comments from NI here clearly show that they ignore this forum. They already communicated that git support is in the roadmap.
But for some reason, 3 years were not enough for someone to take up this topic here.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
HarshaBhushan
Status changed to: Under Consideration
BapiM
While integrating Git with the Sequence Editor is under consideration, there is a KB document that specifies how you can configure TestStand File Diff and Merge Utility to compare and merge changes in your sequence files when they are saved in the binary format when using any of the following Git clients
  • Microsoft Visual Studio
  • Atlassian Sourcetree
  • Git Cola
  • GitKraken
  • Tortoise Git
Link to the KB document: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA0VU0000005Nbt0AE&l=en-US
crossrulz
Knight of NI
DapiM, you should look to adding Fork to the KB, as it is a very nice GIT client as well.
HarshaBhushan
Status changed to: Completed
t.kendall
Holy cow, almost in time for the 20th anniversary of git.
